SnowSurfLax »
https://forums.nicoclub.com/snowsurflax-u62711.html
Tue Jan 08, 2008 7:46 am
I would first check the grounding wire on your stereo and amps. I'm assuming you put an aftermarket in as that's when a bad grounding usually happens.
If you haven't put in an aftermarket, you could pull out the alt and take it to autozone or somewhere and they'll test it for you for free.
But 9 times out of 10, if you hear background buzzing on your stereo that correlates with your RPM's, it's definitely bad grounding.
