seyath »
https://forums.nicoclub.com/seyath-u19143.html
Wed Aug 31, 2005 5:40 am
I have an electrical problem with my S13.A few weeks ago, the radio would randomly shut off whenever I stepped on the brakes. The alternator turned out to be bad so I replaced it. The problem stopped. I then also replaced the negative top battery cable, the one from the battery to the engine block. I also got my battery recharged for the problem started happening again. Now nothing works when the car is not running. I can switch it on but the windows won't go down, the seatbelts don't move, the radio and even the clock won't come on. When I start the engine everything works fine. However only when I am pressing the accelerator or cruising. Whenever I let go of the accelerator and press the clutch, or just depress the brakes, the radio shuts off and all the lights become dim. I need help! Still trying to figure this out!
