ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Thu Jul 28, 2005 7:34 pm
a diagnostic test
ignition key is off
a voltmeter is set on amps & hooked up "in series" to the battery terminal
a reading of xx milliAmps is taken
if it is above a set reading (i forgot what the # is; ~<40milliAmps), u start pulling each fuse in the fusebox until the reading drops.
that is to find out which circuit is causing the excessive "draw"
this is from recollection only, since i didn't put this into practice yet :P
(my NICOtot is teething & this gives me something to do while i soothe him on the glider-rocking chair)
