electrical problem of G20
slin
1991 G20 dash board light, safety belt light, and window motor. My 1991 G20 has been acting oddly for a year also. First the dashboard light may go off and I have to press/rotate the intensity adjustment wheel to get it back or sometime it will come back on by itself. Now the seatbelt light will come on and off by itself even though I have seatbelt secured. At times, the window motor refuses to work once I have it down then I can not get it back up. I can open and close (slam shut) the door and get it to work, sometime. Can someone here shares insight about this problem? Thanks!
zfixxer
You might have multiple problem here. First the dash light might a dimmer switch going bad. sacond is your seat belt light coming on. posible cause might be the seat slide switch or your seat belt track switch if you have the automatic seat belt. third the window more likely is the window motor is starting to go bad too. mostly when you have to bang it to make it work possible the motor brush is worn.
slin
Thank you for the comment. I do have to turn/press the dimmer to get the dashlight back, but it does not stay. Yes, I have an automatic seatbelt and by touching the seatbelt slider attached to door, I can get rid of the seatbelt light. You maybe right with the motor, I was hoping all these come from a bad contact of connector or something.
