slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Tue Mar 08, 2005 10:24 am
Do you have a factory service manual? It lists all the body/chassis ground locations. Check those that are easy to get to, don't go all out. In the S13. there's a SMJ(super-multi-junction) under the D/S dash, above the fuse box. It's a huge connector, with a bolt(in the middle) that pulls the two mating parts together. Unscrew it, pull them apart, and put it back together. Make sure it's screwed down as far as it will go. In a nutshell, this connects the engine bay harness to the instrument harness.
About the only way you're going to find the loose connection(my guess) without going out of your mind following schematics, is the highly technical 'wiggle test'. Seriously, put the key on ACC, and just start wiggling wires/harnesses around. This is about the easiest way to isolate the problem.
Also this may sound silly, but make sure you are measuring from a *good* ground when crawling around under the dash. When diagnosing some electrical problems, I made the mistake of assuming that grounds were there that should have been. You can do this to double check individual grounds: run a long, fused wire(doesn't have to be thick or pretty, just temporary) from the positive battery terminal inside the car(just run it through the open door, again, not permanent). Using a volt-meter, measure from this known +V, to what should be grounds under the dash. If you get 12V, you know that point is a good ground.
HTH, good luck. Electrical problems can be a PITA.-Slip
