Electrical problem...courtesy of sears auto center
mewt240
Car: multimedia artwork
I had a new battery put in my 92 240 last night. when the tech was hooking it up he accidently reversed the posts. their tester also showed that my Alternator is on it's way out. now when I turn my car off all the accessories are dead, when I start it up they come on but not right away(until I am driving). no tach, speedo, radio, turn signals, nothing except headlights. I'm going to the dealer on monday to have it diagnosed but I wnated to get some input here too. I know electrical issues are a *****, has anyone else had this happen? if so what was the problem? fusible link?
yellow_jacket
Car: 95 240sx
check all of your fuses.
Exar-Kun
Car: 2005 350Z
if he reversed the posts, more than likely, a few fuses are blwon, possibly a major one (probably nearly burned out the acessory fuse or something)
other than that, I dunno...you may have to check for shorts in the system after checking the fuses, but I am decidedly no electrical expert.-chet
U12 2NR
make them fix it.
Nismo_Freak
Car: 89 Nissan 240SX
Yes, take it back immediately and have them diagnose and fix the problem.
Stuntman240
Car: 91 coupe
have them check the ecu, if im not mistaken this can also e damaged in this manner, but i could be wrong
mewt240
SEA'rs will pa'Y FOR THe' da'M'Age tHEY CA'used. the service ma'NAger aT SEArs saID TO T'Ake IT TO THE DEAler for diaGNOSIS. *sorRy for the craZ§Y TEXT, BUT MY KEYBOArd is aBOUT **** THE BED.
GroundZero
ok who let little timmy play with xanax?
mewt240
what's that a south park reference? I'm at a different computer now, so It doesn't look like I'm on crack. I figure it's at least two or three of my fusible links for my accessories at the minimum. what is also happening is when I touch the brake pedal when in gear and I am moving, the stereo resets like the car was shut off, ebrake light comes, tach drops. weird stuff...:confused:
GroundZero
mewt240 wrote:what's that a south park reference?
no, it just looked like a 6 year old on pills wrote that post, didn't mean to piss you off
