It happens intermittently. I would attempt to crawl around and test the grounds, but I'm not sure how
I do have a test light however, how does one go about doing this?
Whats a good source for a wiring diagram for my car? The factory service manual? I do notice that the device that controls my seatbealts underneath the center console makes odd noises. Could that failing causing the other failures, or is it likely that someother failure is causing that device to fail? I ask because I can easily get a new one but want to know if this might solve the problem, or if its just a symptom.
