Electrical prblem
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
I have a 93 nissan 240 sx with silvia conversion.Every night when i start my car the light on the climate control dose no come on also the dash light appear dim the when i hit the gas the become brighter also the swivle boolt on the altenator has shaken the nut that holds the alt. to the motor loose constantly and the adjustment bolt that bolt into the alt a un screws its self when i drive i have had to tighten it twice anyway if some has any answers let me know thanks
Dattebayo
get a new alternator?
take it to a shop?
you sound like you dont really work on cars alot, and it really doesnt cost that much to fix an alternator. Which motor is in the thing anyway? SR? CA? KA?
sean8564
1993 Nissan Silvia
The Alt. is a new one. and i own my own body shop
Dattebayo
I figured you knew body stuff.I hope you got one of the brand new alternators, cause some of those part-store alts are real crap. I had one from a part store that had a bad voltage regulator straight from the store. Then the replacement they gave me crapped out a month later. Then i got a new one from nissan and no more problems. Even now, three years later.
slipnfall
Car: '06 D40
As far as the loosening nuts: are there lockwashers under them? The adjustment screw, do you mean the one used to tension the belt? Either way, use some loctite thread locker(red version, can be broken loose w/hand tools later). Great stuff... they make it in a 'chap-stick' style applicator now, which makes it easier/less messy when applying to bolt threads.
HTH-Jamie
eddiec
Car: 91 S13
yeah make sure those lock washers are under all the alternator fasteners. loctite maybe overkill. a locker nut would be an alternative.
slipnfall
Car: '06 D40
Well I sugested loctite on the belt tensioner screw, because there is no 'nut' to put a washer under.
Cheers,-Jamie
absolute
Car: racing,drawing,raping,games,girls
also if you do it yourself just make sure you have the proper tension on the belt too little tension could sometimes give the same effect
sean8564
1993 Nissan Silvia
we'll I took the alt back to auto zone and i was a bad volt regulator and it was killing my batt. and very thing else electronically i put a new alt. on and is seem fine but as far a the bolt problem they are the other two bolts not the belt tensionor bolt they are the swivile bolt on the bottom and the bolt on the top that goes into the alt and they are still shaking loose
