Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Thu Nov 18, 2004 6:32 pm
I stuck a 98 S14 SR into my 93 chasis and it wasn't that difficult when it came to the wiring and I had to run wires from the ECU all the way to the front of the car. For you, it should be a snap. The most you probably need to do is relocate a couple of wires on the S14's power plug. The big white plug that's attached to the wiring harness other then the blue ECU plug. Should be a complete walk in the park.
If you are gonna buy, get the front clip. It costs more but it comes with everything complete with no need to buy extra things, just fuel pump. If you buy a 1500 engine, chances are, it's not complete and condition probably stinks resulting in you spending more then 3k for the clip.
