heres a link to the pic http://www.flickr.com/photos/josiah-pat ... 006111281/
loystock wrote:AFAIK, the electronic engine mounts are designed to reduce vibration at idle, especially on a cold engine. The ECM commands the mount to soften at idle and stiffen beyond 1500 RPM. The FET power transistor (by NEC) is inside the ECU. Unfortunately, when the electronic engine mount is short circuited, aside from blowing the NEC power transistor in the ECU, it may also cause the other FETs in proximity (like the FET for Idle Control) to fail. You may end up with a troublesome P0505 trouble code. And dealer will usually recommend replacing the ECU, IACV and motor mounts... OUCH!
A short circuit in the IACV stepper motor or Electronic Motor Mount may 'kill' the ECU. If you are good with soldering, you can probably replace the 'fried' component(s) yourself. But too much heat may impair the transistor while a 'cold solder' may render it erratic.
Disconnecting the electronic engine mount connector will revert it like a regular mount. No trouble code will be generated as it is an open loop (command sent by the ECU to the mount is not monitored). You may not even know the difference, especially if your engine is in good condition.
