Electrical Issues
General discussion area for the L32-chassis Altima
tlord1000
Car: 2007 Nissan Altima
I have a 2007 Altima. My electric door locks, windows, flashers, turn signals, etc. are not working. However, my headlights, break lights, radio, ignition, dash lights, etc., are working. I want to know if this is a fuse or relay problem. Is there a main accessory power fuse? Could it be a problem with the positive battery fuse connector/cable holder link?
PapaSmurf2k3
Site Admin
Yup, I would guess fuse. You COULD try to look through the FSM to find which one:
www.nicoclub.com/FSM
Or you could just pull the panels and look for ones that might be labeled as interior lights, "accessories", etc.
tlord1000
Thanks for your reply: Unfortunately, I have looked at all the fuses under the hood and in the fuse box in the cabin on the driver's side and cannot find any blown fuses. That's why I think it might be something else.
PapaSmurf2k3
Site Admin
Yeah that's very strange indeed.
telcoman
tlord1000 wrote:I have a 2007 Altima. My electric door locks, windows, flashers, turn signals, etc. are not working. However, my headlights, break lights, radio, ignition, dash lights, etc., are working. I want to know if this is a fuse or relay problem. Is there a main accessory power fuse? Could it be a problem with the positive battery fuse connector/cable holder link?
There may be a fusible link located at the positive battery terminal that is open?
Was your battery recently replaced?
Use a voltmeter to start tracing. You may also have a loose connecter somewhere
As others have mentioned follow the electrical schematic in the FSM.
It may also be a loose or missing ground
Good luck
Telcoman
Louieg3d
Car: 2010 nissan altima 2.5s
I have a 2010 altima 2.5s, and I have a big problem with it, one day on my way home from work all of a sudden all my dash lights came on and the spedometer and tach both went dead and the car lost all power and after a few seconds or minutes the car would start itself back up. This would only happen a few times and the other times it's ok but it's very frustrating because I don't want to be stranded. Any help would be appreciated thank you
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
Check online to see if there's a TSB related to the problem you described. Worse case scenario take your car to the dealership or call the service department to see if they've dealt with this problem before.
Return to “4th Generation Altima Sedan (2007-2012)”
