electrical issues.
Nismoman!
Car: 1990 240sx Coupe
First of all I've got my rebuilt 1990 240sx Ka24e running smooth and titled.But now I'm getting to a more touchy subject,
The issue'(s) are with my rear brake lights and both front turn signals.The tail lights are working fine with my lights turned on but when I hit the brakes the lights on the passenger side (go out), and the drivers side lights up as it should when hitting the brakes.
& Both front turn signals are not working, cleaned the bulb connection and am using new bulbs.
Wiring diagrams would help a lot..
ThanksGreg
vancouverbc
Car: 1991 240sx
there are wiring diagrams for 1991 in tutorial link in my signature . look up wiring. not sure if it is the same or similar to 90
there is a link to a 89 factory service manual in my signature.
h.240
Car: 1991 240sx hatchback
That is quite the electrical problem. I would start by pulling the actual light housings and check the connectors that go into the back of them to see if all the wires are connected and they are in good shape. By the sounds of things you recently got this car so the person before you may have messed something up while working on it. If they are present trace them back as far as possible to see if they are cut.
Nismoman!
I've had the car about 4 years, starting with rebuilding the motor and everything from the radiator to the gas tank is new or refurbished. But when i got the car it had been in a storage lot, for about 3 & 1/2 years, only $200 bucks though, no rust 80,000 miles on the chasis. all original. and the wires all look fine no corrosion.
Thanks for re-posting
Greg
