buckwild wrote:
1. The first would be the front speakers making a high pitched noise and you could barely hear any music unless you turned the volume all the way up.
2. Second would be the passenger window would work without any problems and then one day I rolled it down for a second and then it just died. I took the window off track (like the rear two) cause I thought the motor went. Well a few days later the motor made a buzz and it was working again.
3. Third is the gas gauge, it never seems to float at the proper level. It seems to stay at half a tank when I get gas and then it doesn't seem to want to drop below 1/4 tank.
4. And the last issue is the temp control unit which I've seen already as a common issue with the LCD going in and out. Mine only came on once then as soon as it came on it went off. I was thinking about the ecu being the issue. Has anyone had any of these symptoms? Also I did search for related issues and I haven't some across anything similar.
Thanks for any and all help.
Welcome to NICO! Glad the site has helped.
I can offer a couple answers.
1. The amps in your Bose speakers are probably shot. More specifically, the capacitors go bad with age. There are a couple places on the net where you can get them rebuilt for $100 or so.
3. It sounds like your float is bent. This often happens when someone not acquainted with the Q replaces the fuel pump - they try to go through the trunk instead of the back seat and it's too tight that way - float gets bent when the new pump is installed. Any evidence of it being replaced? If so, you can go back in and pull the pump and straighten the float - not exactly easy, but not impossible either.
I doubt it's ECU issues.
[Edit] I see Wes answered you in Infiniti Online Mechanic. Try not to cross post.
Modified by 96Qowner at 2:56 PM 1/9/2007
