Electrical issues. s13 ka42de
macneil
Car: 92 S13 coupe -sr20- 340whp
08 g37s -VQ37- 300whp
so I just replaced the head gasket on my ka24de, car starts and idles fine, but the steel braided ground wire that grounds the head to the firewall keeps getting very hot when and only when the engine is running.
I have been using a multimeter to check resistance at different points on the car, and have also replaced alot of relays & the TCM. I disconnected the battery and tested from the hot wire to the chassis. It reads 0 ohms (dead short) for 2 secs then climes to in the 200's all the way into the 1000's until finally reaches a open circuit. (This is with the key out the ignition)
I am sort of lost at this point, and getting frustrated as hell. Does anyone have any suggestions?
charat
Car: 1992 Nissan 240sx SE, 2008 Honda civic EX
uhhh you might have some frayed wires somewhere and some wires are crossing? fuses? ionno... this might be a biggy. might need to check your whole electrical system.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Replace that old ground for sure. What kinda meter are you using.
macneil
The meter is a Fluke T5-1000 Multimeter. It more for ac electric then dc. It doesn't read Dc amperage. I am an electrician by trade, and normally troubleshoot auto electric problems easily. I thought it was odd how the resistance slowly got higher from 0 (dead short) to an open circuit, and this is with the battery disconnected. My other car is a s13 coupe, I will check if it does the same thing, but I doubt it will.
macneil
So my coupe does not do the same thing, when reading resistance on that it holds 60 ohms with no dead short. So I will be tracking down where this short circuit is happening on my hatch and will keep everyone updated.
