the_momo »
https://forums.nicoclub.com/the-momo-u29599.html
Sat Jun 11, 2005 6:09 am
really any cap would do as you arent running a lot of power... better quality will definitely make a bigger difference... tsunami makes good caps, id go with something around 2 farad with a voltage readout then you could actually see when and from what you are getting the voltage fluctuations.
drift makes a good point though, if the altenator is bad the you arent generating any power, check that and if it is good get the battery and a cap, itll help a lot more in the long run.
