VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Thu Nov 13, 2025 8:37 pm
If you're certain the battery is good, then plainly you have a cabling problem. If you changed the battery without changing the lugs, it's possible you simply have some green rock candy mountains hiding inside the old positive lug. Gen5 Altimas also have a 2-piece ground lug to allow the battery current sensor to be separate from the cable, but if the nut holding the cable to the lug comes loose it can create enough resistance to disable the car. Make sure that nut is tight. Lastly, the battery cards can sometimes fatigue and crack internally where they right-angle, which can cause the same sort of resistance on the power side. In addition, the cards also have a nut and stud arrangement where they attach to the lug, those can corrode in between the card and lug where the corrosion can't be seen without separating them.
