ELECTRICAL HELP?
Chief1402
Car: 1996 Nissan 240sx Converted to 5 speed, kouki front/rear, jdm front end. :)
Hi, I have a 96 base 240, jdm kouki front end. I just got a set of jdm fogs and they're mounted to the car, but I found that the plugs on my car don't match the ones on the fogs... does anyone know where I can find the correct pigtails? Or should I cut the plugs off and just mate the wires together??
Hijacker
Car: '92 240sx Convertible
'94 F-150
Call up the guys at the Nismo Shop (West Covina Nissan). They can hopefully order the proper plugs for you. If you don't want to order the plugs, your options then are to cut the harness and use crimp male/female spade connectors or you can source any matched pair of 2 prong exterior harness plugs and just solder them in. Don't forget you'll need a blue relay as well as the the light switch (p/n 25540-70F62). I would check with Nismo Shop about the light switch as I'm not sure if that's a JDM p/n or a USDM p/n. If it's JDM, you'll need someone like TNS that can order from the JDM catalog, but if it's USDM, you can order it from any dealership.
Chief1402
I appreciate the help, I've already got the lever and relay, I think I found the correct plugs for the lights.. they're off a 300zx side markers
