DanielC »
https://forums.nicoclub.com/danielc-u110482.html
Wed Dec 31, 1969 5:00 pm
A little of electrical theory here. Generators sometimes use a residual magnetisim in the field to start generating voltage. The regulator keeps the generator isolated from the rest of the electrical system, until it is creating a voltage above that of the battery. If a generator sits for a long time, it can lose its residual magnetisn it needs to start generating a voltage, or worse, sometimes the magnetic polarity can switch, and the generator will become negitive ground on a positive ground system, and short the battery when the generator creates enough voltage to trip the voltage regulator.
The generator must be polarized if the charging system is worked on.
I am sorry, I do not remember the procedure for polarizing a generator on a Datsun, All my Datsuns have alternators.
