electrical hell HELP!
ventrex
Car: 1993 Nissan 240SX Coupe
im located in massachusetts.... and a garage put in an SR20 Black top swap in which they had an entire front clip to work from. The car drives/runs nice, but the eletrcial was all messed up, problems:
1. Speedometer doesnt work
Modified by ventrex at 3:46 PM 5/19/2007
VeloceDrift
Car: 1993 Nissan 240SX S13 coupe
1995 Nissan KA24DET
Did they put the entire front clip on your car? if they did not then their is no reason why your lights should not be working because the you only have to modify the engine harness. For the Speedometer it is probably because if they put in an SR transmission as well then they probably didnt hook up the Speedo wire and if they did then it would read Kilos not MPH so it does not help you to much.
Jasong
If your speedometer shows kilos and mph the sr speed sensor is the correct one. Which I don't know if s14 or s15's show both but both my s13's do.
otterball21
Car: 1995 240sx
such a shame that your not down here.. I would help you out!
