darkspoon »
https://forums.nicoclub.com/darkspoon-u86733.html
Sat Jun 07, 2008 8:46 am
Check a FSM for wiring on your starter, don't jimmy up things to make them work.
Check your alternator in car, when the vehicle is running with a multimeter. If its charging properly with the car started it should be around 14V, and if it is working then you might have a pooched battery.
For the gas tank, drop it and clean it out. Get the crud out of it and inspect the inside of the gas tank for rust. If its rusty on the inside scrap it and find a new one. If it isn't and just **** has been falling into your gas tank then its fine, mount it back up and you are good to go
