electrical contact problem
natsoundup
When I put my lights on in either parking light mode or full lamp mode.... my left hand turn signal blinks quickly....as if a bulb is out...
...but no bulbs are out.... it blinks normal when the lights are not turned on...
I know in the scheme of things this isn't very big.... just asking...
tonight, I will remove the bulbs and sand the contacts....come to think of it I will spring for a couple of new bulbs...
timatt
So does the turn signal bulb actually flash (albeit rapidly) when the lights are turned on?
Also, is this a new problem or has it done this since you've owned the vehicle?
Try new bulbs first.
timatt
natsoundup
first time it has happened with the bulbs actually flashing...i was sure when i got out of the car today..one bulb would have been burned out...
natsoundup
apparently the left front park bulb was causing the issue...it was possibly not making correct contact... as I tried to pull off the housing...it started blinking correctly...I just buttoned everything back up...
I suspect it will happen again...I will have to pull the bulb out and check the contact the next time it happens....
