Once you open the box, you will know what to do. I snapped some pics just now to give you some tips I learned through trial and error.
There will be three main pieces:
2 x DRLs with wiring and a connector at the end, and 1 x Switch box.
The switch box will have two sets of wires coming out of opposite ends, One end has a set of wires that have connectors on them - you plug the DRL wires into them - ** doesn't matter which DRL goes to which connector, but do NOT connect them until the entire install is done. Once connected, they are hard to disconnect.
The opposite end of the switch box also has two wires. One is the set of red and black wires to connect to the battery - red to (+) and black to (-). The remaining wire is optional. This wire goes to the headlamp socket IF you want the DRLs to go dimmer when the headlamps are ON. I didn't use it and cut it off from the switch box.
I ran the battery wires under the black battery box and up to the battery. ** Make sure you connect these wires and the battery cables VERY tight as our cars act up if there is any loose connection at the battery terminals.
I placed the switch box against the metal wheel well and secured it with a cable tie. ** You have to place the box in a location that where it won't rest against, or be subjected to high heat sources like the engine or hoses.
After you have installed the actual DRLs, just run the wires up through the engine bay. I ran them in front of the radiator and across the top of the engine bay just under the hood latch, then under the washer tank, etc to the connectors on the switch box. You will see where I cut the extra wire that is used for connection to the headlamp.
Depending on how much of a 'lip' there is down on the bumper insert, you may be able to just drill a small hole behind each DRL to run the wires. On my 07, that's all I had to do. I used 3M double stick tape. NOT the tape you see in the grocery. You need the 20-lb rated 3M tape that you will find at Home Depot or the like. On my 09, there wasn't enough of a lip to make it easy so I had to cut out enough of the bumper insert to allow for the DRL to sit flush with the bumper. In both cases, though I did not use the metal brackets that came with the DRLs. I used 3M tape and it holds up to cold temps, hot temps, rain, snow, etc.
Hope this helps !
