Electrical: aem f/ic cranshaft position sensor
s14drifter69
Car: 1995 Nissan 240sx
Hey guys my name is julio. i have a 1995 240sx ka-t i have an aem f/ic and i did all my wiring but i cant seem to find how to put the cables for the crankshaft sensor. the fic has 4 cables wich are. CRK MAGi+, CRK MAGi-. <=== this 2 are from sensor to FIC. CRK MAGo-, CRK MAGo+ <=== This 2 goes to the ecu. now the 95 harness has only 1 cable is pin # 53 (PINK). i need some diagrams or if some one have done it b4 to help me out plz thanks.
Justinians_2:40
Car: 95 240sx
If you need a wiring diagram for the car, you can get one at the website in my sig, in the fsm section, other than that, I'm not too familiar with these.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
I just took a quick look at the FSM wiring diagram for the cam position sensor. The wires that you want are a white wire that splits to pin 40 and 44 at the ecu, and a black wire that splits to pin 41 and 45. You'll hook up the cam 1+2 hall wires to those. There are pink and black wires at pins 50 and 53 respectively, but you shouldn't have to connect those since the ecu only uses them for miss-fire detection and nothing timing related. Let me know if you have any other questions.
In case no one else has said it yet, welcome to NICO!
