petertearai »
https://forums.nicoclub.com/petertearai-u215994.html
Fri Feb 15, 2013 6:42 pm
Hi I have a 1997 nissan sentra .The pasenger window would not drive up. I took 12 volts directly to the motor I can drive up and down directly, but only down with the system conected normaly. I have checked the voltage at the plug to motor location and I get neg 12 volts and pos 12 volts. But still it will only move down. Is there a master controll box. Dose it have special curent limiting? Where is it located. Any help would much appreciated Regards Peter
