Brandon1605 »
https://forums.nicoclub.com/brandon1605-u132519.html
Fri Oct 09, 2009 2:25 pm
The problem is the regulator, not the motor. But, depending on the year, you probably will have to buy them both anyway if you go new. Anyway, the rule of thumb is that if the motor still works, but the window is farked, the regulator is the issue. If the window does nothing and the motor makes no noise, then its the motor. Hope that helps, bro.
