Ligouri Rd »
https://forums.nicoclub.com/ligouri-rd-u1844.html
Tue Jul 27, 2004 10:03 am
Ha! I love this:Quote »Most other electric supercharge systems work on a 12 volt system, and just dont have enough power in the electric motor to create the same static pressure this motor does. The power of this 110 volt motor is far more than that of any 12 volt system, and will create more static pressure. [/quote]Power is power=Volts X Amps. An inverter merely sacrifices the amps to make more volts. You actually will waste some power in wire resistance in the inverter. That "supercharger" is just a high cfm attic blower (hence the 110) with a cone filter stuck on it. Try Grainger or McMasterCarr (.com), I'm sure youll find the same thing much cheaper.
