wankelTII »
https://forums.nicoclub.com/wankeltii-u48978.html
Thu Dec 28, 2006 9:02 pm
If you are hooked directly to the battery then you should also be hooked directly to the charging system, no reason to change where your wires are connected, unless you are removing it!
You would be better off with a ram air intake. Forget leaf blowers, if your really lucky they MIGHT work better than the average aftermarket hot air intake, but even so its still stupid. All of these companies market crap "cold air" and "short ram" intakes and they are ok sometimes, but often they make less power than stock. And (power wise) ANY intake that pulls air from the engine bay is stupid, if you dont believe me, put an outdoor thermometer on your fender well, where most everyone has their little cone filters and go for a spirited drive for say 20-30 minutes.
Nothing can beat an air box that becomes pressurized with outside air at speed. A filter that has a good amount of surface area. And a venturi shape protruding into the air box on the end of a tube that makes smooth gradual bends around whatever it needs to on its way to the intake manifold. K.I.S.S. is my advice.
