EZcheese15 »
https://forums.nicoclub.com/ezcheese15-u102.html
Sun Mar 30, 2008 2:57 pm
I did this once on my old 210 with a leaf blower. No lie, it's a goods story when I'm drunk...
The problem is that to produce enough amperage to make the blower produce enough pressure to make a difference, you have to have a huge power converter. I used a 500 amp converter, and it barely had enough power to turn the blower. Even with a 1000 amp converter, its not going to be very powerful. And to go to a higher amperage converter, you have to start measuring the cost between a power converter and a real turbo or supercharger. It simply isn't worth it, but it makes for a great story
I can tell you this however, it works AWESOME when not trying to run it off a car battery (I tried it again with a long extension cord and plugged in). Problem you run into is that you can only go about 100 feet or so LOL.
