Pull the seat and look for coins in the track. They will be down by the seatbelt buckle.osu9400 wrote:The driver's side electric seat stopped moving forwards/backwards. Luckily it's stuck at the right position for my size. The motor works and actually one side of the seat tries to move. As far as a I can tell, underneath each side of the seat is cork-screw that goes into some type of gear box. Both screws move, but it only catches one of the gear boxes. Is it possible to purchase just one of these gearboxes (or whatever they are called)?
Thanks.
He is correct. There is a Nissan Technical Bulletin out for this very problem and any tech at your local Nissan dealer will be more than able to take care of that problem.hagoth wrote:there is actually a TSB for this so there is a kit that they can sell just the motor from.
