Morph »
https://forums.nicoclub.com/morph-u11938.html
Sun Jun 01, 2008 9:24 am
Lil update, finished the clutch swap replaced with a stage 3 from spec. Got the flywheel resurfaced at AAMCO for 30 bucks. I had a ***** of a time getting pressure in the clutch, so I removed the clutch dampner box and bent the hard line around to fit to the clutch hose. Problem there b.c i effed up the fitting and had to cut the flair off and try another fitting. Problem there is no matter how many times I reflaired the end it would not seal properly. So i headed to the junk yard and got the left front brake line off a vert 240. Rebent that and now i have great clutch pressure( till the ss line gets here monday) but the god damn noise is still there. As cody suggested Im thinking its the input shaft bearing. From what everyone else has said about this the best/easiest is to get a new trans or rebuilt one. B/c apparently is very hard to remove and reinstall the bearing. Any one else got any opinions????
