electric issues
asuliman1
Car: 2004 infiniti G35 coupe
So I'm having a problem with electric (grounding) and wen I come to turn the car on one of my grounds heats up and cuts in half .... I got a temp cable and I jump it and it works but then another issue I found out was shifter (auto ) gets stuck on park and I can temp. unlock it using the shift lock thing . And then another problem I have is the most concerning .... My instrument panel doesn't work including defrost heat ac all that would that be a fuse prob and if it is where could that fuse be and if anyone can be specific enough to tell me what's the fuse number lol help plz
2004 Infiniti g35 coupe btw
joe603
Car: 2014 Durango R/T
Let me get this straight...you start the car and a ground wire burns out enough to destroy the wire? Was the car flood damaged? What happens to the "temp" wire? The issue could be affecting your transmission electrical. I would have a dealer or a trusted mechanic look at it. Sounds like a fire hazard.
The heat/AC issue is probably the radio unit. On 03-04 models, it's a known issue that can affect the AC/Heat controls (they share a common circuit board). These guys can help you with that: http://www.shortcircuitrepair.com/
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Your help is at the dealership... have the car towed there and properly checked out by a technician.
