racerken wrote:I used a 1/2" breaker bar plus lots of break free.
That's my initial instinct. If I'm facing a tough bolt, I'd rather go for leverage power than hammering power.
Maybe it's just because the breaker bar is right there. But with the impact wrench, I have to dig it out, the impact sockets out, fumble around with an extension cord, etc. Ya, I'm lazy.
I mostly use the impact wrench if there's a lot of bolts/lugs that require lots of torque to get off -- the cliché example being changing four tires, that's 24 lugs. Or I might use an impact wrench (or a power drill) if the threaded portion of the bolt was particularly long, so I could just *zip* it off. I'd also try it if, for some reason, I couldn't get a bolt off with a breaker bar, or if the breaker bar didn't fit where I wanted it to and I couldn't use an extension.
In short though... it's always nice to have multiple, different tools that do the same job, just in case one fails.
