A 1980 720 I recently picked up, has an electric fuel pump installed and the original mechanical pump removed. I noticed while checking the valve/rocker arm assembly, that the offset actuator on the front of the cam that ran the original mechanical pump, is still attached. It is "extremely" worn. I am concerned about possible balance issues. Should I remove it or leave it on there?
Thanks in advance for any replies.
