What I actually planned to do was...since I have a 91 DOHC that has an auxiliary AC fan already, I was gonna get an FAL electric to put on the condensor itself on the front to push air through and wire both Altima fans to trigger simultaneously on the radiator side of things.zero_gripS13 wrote:almtima fans.. wired to a thermoswitch to turn on one low speed at normal temps then another or use the a/c plug to turn the other fan on high speed when heat gets too high (i think 210* is what its set at)
correct me if im wrong...
Yeah, the ECU turns on the cooling fan to low speed at 203F, assuming the a/c is off, and to high speed at 212F.zero_gripS13 wrote:almtima fans.. wired to a thermoswitch to turn on one low speed at normal temps then another or use the a/c plug to turn the other fan on high speed when heat gets too high (i think 210* is what its set at)
