Rhoad Racing »
https://forums.nicoclub.com/rhoad-racing-u14318.html
Sat Apr 10, 2004 7:18 pm
definalty put the shroud back in. From what I've read, the shroud is pivital when it comes to direction of the air flow. However, even without a shroud, I don't think should have to blast the heat. Which makes me think that it is your t-stat. Take it out and leave it out. Drive the car normally (after resealing everything of course). If the car still overheats then you may have an air pocket in the cooling system or possibly the water pump going bad. On the other hand, if the car doesn't over heat with the t-stat in, then you know that is was faulty.
But also keep in mind what deviousKA said too.
