Electric fans on rb25? and n e one running a downpipe only?
iamadirtdude
Car: evo 9 & s13
I was wondering bang for your buck if the slim line fans seem to be the best i dont want to spend over 120 if possible. also anyone heard of any problems you can run into running a downpipe only besides police lol?
iamadirtdude
Car: evo 9 & s13
you guys have to be runnin fans whats out there?
rotorimp
Car: 02 Xterra, 60 IH Metro
I have FAL pullers with griffin rad--not cost effective--If your on a budget go to the junkyard. Open down pipe--I say rock on!!!
iamadirtdude
Car: evo 9 & s13
i was goin to run 2 10's or 2 12's if they fit on a koyo should run them pulling correct?. and i thought it might be bad *** to run a 4inch out behind the front wheel after the downpipe heh
Joe
open exhaust is LOUD AS ****ING HELL. you will get pulled over and ticketed. not only that but if you ever plan on USING the car for something most racing organizations say the exhaust has to exit past the driver.
i have a side exhaist with no muffler or cat and while it sounds bitchin, its not a street exhaust lol
and fitting pullers is hard, please search as this has been covered many times.
rotorimp
Hell yea that would be bad @$$. I'm going with a open waste gate dump tube. As far as the fans--Go with the room that you have which depends on the mounts.
rustbucket
Car: '90 s13 RB25DET SII
If your gonna be driving the car alot you better move the exhaust past the driver. I ran an open dp ending right under the drivers seat. It is super loud(like your ears ring for about an hour after driving loud), my car is gutted and the sound just resonates. The exhaust also leaks into the car if you dont put it back far enough. I would say a pipe coming out infront of the rear tire atleast.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Hey why dont you look upt that Quick Time performance exhaust cutout.
Its electric so you just push the button and open it up or close it.I'm sure your GF along with the rest of the town will appreciate it.
Also if your interested I've got a 13" SPAL pusher fan for sale Brand new still in the box.
iamadirtdude
Car: evo 9 & s13
that would be nice but i still havent figured out if i need a pusher or puller, and i dont know what you want for it but i cant go higher than like 120$
iamadirtdude
Car: evo 9 & s13
anyone using an rb25 in a 240? pusher or puller better?
skribblah
hey kamin...got any sound clips of your car running open dp? i'd love to hear...
Joe
skribblah wrote:hey kamin...got any sound clips of your car running open dp? i'd love to hear...
no DIRECT revving clips, but i have one from one of my events a couple months ago
http://video.google.com/videop...hl=en
@ 43 seconds is me and my car. you can get an idea how loud it is compared to the others out there.
Sil240
iamadirtdude wrote:anyone using an rb25 in a 240? pusher or puller better?
What are you using mounts or the skyline x-member?If your using the xmember then you have to use Pushers.
If you have mounts that pull the motor back farther then you can fit Slimline Pullers.
I have mounts but I still use the same 13" SPAL Pusher fan.With my rad I don't have much room between the motor and the rad.
iamadirtdude
Car: evo 9 & s13
im going to use the syko kit w/ r33 xmember which supposedly moves the engine back a little, with a koyo which are supposedly thick lol. for my price i think i'm goign to use dual 10" slimlines.... i thick you can run them universal push or pull
iamadirtdude
Car: evo 9 & s13
anyone have slim lines on an rb25 and know if i can fit 12's or just 10's
SStrunks
Car: 1994 Honda Accord & Soon to be a RB25DET S14
iamadirtdude wrote:im going to use the syko kit w/ r33 xmember which supposedly moves the engine back a little, with a koyo which are supposedly thick lol. for my price i think i'm goign to use dual 10" slimlines.... i thick you can run them universal push or pull
Im using the same kit and I too am alittle curious on what to use for cooling. From reading on the syko faq page, they used in their s13 twin FAL pullers and the stock s14 radiator. They also mention that if you wanna use a thicker aftermarket radiator (Koyo) youre gonna have to get pushers. One other method mentioned is one puller and one pusher in the front....
For me I think I'm gonna try to get fluidyne radiator and dual pullers, it'll probably fit since fluidyne is fairly slim compared to koyo.
Modified by SStrunks at 2:34 PM 4/11/2007
blurrbosi
Car: 240's
I'm still wondering what fans to use with my set up, JGY mounts (tophats) stock s14 rad.
roadrunr
Car: 1992 Nissan 240SX Convertible
Can these aftermarket fans be wired into the ECU circuit to automatically switch on and off? Has anyone wired them in yet, if so, which wires go where?
Chaos the Xile
Car: 1974 Datsun 260Z
i have a exhaust leak and it is loud as s h i t! Get a exhaust system!
Sil240
Nope,
The stock ecu doesn't have any temp dependent outputs. Plus even if it did, how would you set it?
You can buy a fan controller or just get a thermostat. That's what I'm running
blurrbosi
Car: 240's
So if I buy this,http://www.xatracing.com/store...d/889
And this, http://www.xatracing.com/store...d/890
I should be good? This fan is reversable, and the shop is local. Can anyone beat this price or should i go FAL for 289 w/ controller...???
