electric fans not coming on, need wiring diagrams or help
tricktoyz14
Car: 1989 nissan 240 sx
my electric fans arent coming on because the wires are cut, and i need to know where to splice them back in or hook them up. on both fans there are two plugs one with three white wires and one with one black wire i believe, i didnt know if i just needed to splice alll them together or if they both hook up to something different, any help is appreciated!! im tired of my car over heating.
Second Shadow
Car: 93' 240sx, s13 blacktop sr20det
are these new/recently installed fans or did you have them working before?
the black wire is your ground, but normally you just need 1 other wire for your 12V hot, which you should have hooked up to a fan controller, a switch in the dash(not a good idea though, if you forget to turn them off it will kill you battery), or a relay network powered by the fuel pump relay.
I would ground the black wire on the chassis, then put 12V from the battery on each of the white wires to see which on is the hot lead(it will be the one that turns the fans on).
tricktoyz14
ill try that, i was thinking of doing that earlier but i didnt wanna short it out or something, ill let you know how it comes out.if i find the hot wire i wanna hook it up through a relay or a fuse that is only hot when the key is on, what would be a good one to do that with
Cone Junky
Car: S13 fastback
BMW e46 328i
Hooking them up to be on with ignition isn't proper. Our cars are designed to run in a certain temp range. Running the fans constantly or removing the thermostat will not let the engine get to and maintain proper temperature.
I strongly recommend using a fuse, relay, and thermostatic switch to run the fans.If you can't wire them up properly, don't switch to electric fans. I don't know why people are willing to destroy their engines to free up the whole 1HP the fan clutch uses...
tricktoyz14
what all do i need to do to do that, how would i wire in a relay and all that stuff? im very new to the electrical part of cars, im use to carburated engines and all that
