Electric Fan Wiring
islandtuner242
Car: 1990 Nissan 300zx N/A 2+2 SOLD!!!
2003 Infiniti G35
ok last night i picked up my new (used) radiator and electric fans....so i'm trying to wire it up but came to no avail this is how i had it.... power is hot wired to the battery and a separate wire in the condenser fan relay and the fans are grounded off, does anyone else have this setup if so the help is greatly needed seeing as how my Z is my DD
Thanks In Advance
car nut
Car: GT500.
That should work fine, is it a two speed fan? Also, if you can I would just use your stock mechanical fan, it flows way more than an e-fan ever could.
islandtuner242
2003 Infiniti G35
yea it's a two speed and i can't find the stock clutch fan....it broke off taking the pulley with it while i was headed home
