corey240 »
https://forums.nicoclub.com/corey240-u32370.html
Wed Jul 09, 2008 5:56 pm
So theres different ways to do it. Im looking for cheap, effective, and reliable. 3 words that usualy do not go together in this world. My Flexalites are wired to stock relays, which are allways going bad. So im going alternative. Instead of a dif controller or any of them, my friend showed me a new route.
On a Honda there fans are controlled by a stock sensor in the waterneck I believe it was. So im gona do the same. Wire up a relay, Positive to the battery, opposite to the fan. Positive from the battery again, then take the ground post (of the relay) and run it to the sensor (from the Honda) thenn from the Honda sensor to a ground. Sounds simple (and it is) so im gon give it a shot. But...
I wonderd if you can take the temp sensor from the sr/ka/ser ect... and use it the same way as the "switch" for the fan to kick it. As it would be thermaly controlled. So fans turn on a the set temp and stay on until the temp goes down to the sensors set temp to kick off. The honda is stock like that so i could grab one or like 10 for free from friends lol. Im just wondering if anybody thinks this will not work.
