sonnys240 »
https://forums.nicoclub.com/sonnys240-u17949.html
Thu Jul 08, 2004 8:58 am
Hi, i'am new here and i would like to share a personal experience with you guys. i have a 1990 240sx SOHC and i live in Phoenix. AZ. my car runs hotter than normal in the summer because my a/c fan does not work. temp gauge is always over halfway to overheating with the a/c on. when it starts to overheat, i have to turn the a/c off and turn the heater on to cool the temp down. This Suck in AZ!! in the winter it was ok. so i decided to make more room under the hood by removing the stock fan, the shroud and the broken a/c fan and replace it with 3 12" electric fans i bought from ebay. i think it was around $40 a piece. 2 were rated at something like 1100 cfm and the other was around 600 cfm. the 2 x 1100 (2200)cfm i mounted as a puller and the other was a pusher in front of the condenser. i had the 2 pullers on a adjustable thermo relay to kick on at a certain temp and the pusher splice into the old a/c fan wire to kick on when the a/c is on. i started this project at the end of last summer. it works great for all of the end of that summer and through winter. but temp was running just a litte bit over halfway on the gauge and steady and wasn't rising. i assume everything was fine and dandy until that one faithful hot AZ day. it started again with rising temp and a/c off - heater on. Again This Suck Very Much!!! i went back to ebay looking for higher performance fans and ran across SPAL fans. these are not cheap fans. they had different kind of 12" fans - thins ones to thick ones. the one that interest me was the high performance puller 12". the design was thicker and have only 5 blades and was rated at 1620 cfm and at around $140 a piece. ouch!! i was very skeptical at first because why pay $100 for an extra 500 cfm. so i did a little research and found out that a lot of custom hot rods used SPAL fans to cool down their V-8's. so i took a chance and bought 2 of them. 1620 cfm x 2 = 3240 cfm. i figure what the hell if they can cool their V-8's i can cool my 4 banger too. another project - remove 3 ****ty fans and replace with 2 spal fans. this time i only use 2 fans as a puller no pusher. i wired the fans to my old thermo relay (supposed to support dual fans) and all i can say is WOW.. these 2 fans are really amazing. my temp gauge now is a little below halfway even with a/c on full blast and in the middle of rush hour traffic in Phoenix, AZ (110 degrees +) until the relay blew. my relay was rated to 30 amps- each fans it rated max 20 amps. (these babies suck some juice). like a dumbass, that's the part i did not read up on. so now while i'am waiting for the new dual fan relay (70 amps) to come in, i only have one fan hook up directly to the battery via plug and unplug under the hood just to get me to work and back. this also suck. But all i can say is WOW again with only one fan running the temp gauge is just a little over halfway and not rising even in traffic and a/c full blast. Now i know why these fans are expensive. it is worth every penny. If you have roughly $300 to spend on cooling fans for your 240sx, in my opinion, these fans are the way to go and you will not be disappointed. I hope my experience help out some of you living in hot climate like AZ.. i guess U Get What U Pay For.. Thank you
