electric fan
kaylinsmom
Car: 2001 nissan pathfinder
:confused: :confused: we are trying to replace the old fan with an electric one there is a wire that has to be connected to the battery and also a yellow wire that has to be connected to a 12v ignition source there is a relay and fuse in the kit it came with what can i hook this wire to ?? its a 2001 pathfinder
atraudes
Car: 2001.5 Infiniti QX4 4WD
:welcome:
Your best best would be to tap into the bottom of the fuse box under the hood. There should be plenty of things there that are post-ignition. Consider tapping into two sources, though, to avoid the possibility of the fan not running due to a wiring issue on one item.
doode
Car: 1999.5 Nissan Pathfinder SE
3.3 V6
5 MT
416,000 km and counting
Are you planning on manually controlling it, temperature controlling it or just having it on whenever the ignition is on ?
If you set it up to run when the engine is on you may run into overcooling situations in the winter
Either go manual or consider temperature controlled
http://www.jegs.com/i/JEGS-Performance- ... ProductId=
