nuttin but Z32 wrote:any idea on how to replace the motor fan for an electric and how to make it work?
any help would be great thanks!
Y. Here's what I did:
AshSPECZ double-pass rad & 16" fan
Also get the SPAL Temp Sensor and Fan relay from ebay. I found it cheapest here and they deliver quickly:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWNX%3AIT
It makes installation ridiculously easy!
There is an orange and gray wire built into the kit...gray to (-) switch, orange to (+) ACC.
*Note: In order to defeat the 203 degree fan circuit turn on from ECU, I installed a separate relay (30A SPDT) and a small on/off override switch to basically turn the fan on whenever I needed it. Then attached the ECU fan turn on wire (negative pulse) to the trigger input making sure to add a diode to keep current flow in check.
Ash Powers
"...The pin you are looking for is pin#19 - the wire is blue in color and is 2 positions out from the center bolt. The connection completes a ground when the ECU turns on the fan - connect this wire to a control relay's electromagnet and the other end of the relay to a (+) power source. On the relay switch side, you can run the power to the fan and use the relay's switch to complete the ground for the electric fan..."
That was just about it. It was a fun install and now my cooling is in play for the next stages of upgrades.
I hope you find this information useful and be sure to check before you splice and solder.
PM me if you need more details, but it would be best for all to view the info.
Safety FTW!
