can you hook me up with a pic?rodmod720 wrote:mine is minus a fan the same way but i used shorter bolts and eleminated the clutch altogether. got a fan out of an avenger i had lying around.
haven't done it yet mainly because i'm lazy... i haven't found a replacement fan yet nor though the process out as well as rodmod2kredz3 wrote:i had thought about that, but having the clutch spinning with out dampening from the fan concerns me. is this what you did?
http://www.thefanman.com is the place to get the supplies, that is where i get my cooling needs for my BMW Z3 (hence my screen name )PEZi303 wrote:haven't done it yet mainly because i'm lazy... i haven't found a replacement fan yet nor though the process out as well as rodmod
i have that style water pump as well, after looking at my pump it has no bolts going through it just the center shaft. not, i have air tools and a die grinder. . .i wonder how much of the clutch i can get offnis720 wrote:My experience with my old Z24 had the fan clutch built into the water pump. I had to disassemble the clutch fan itself and leave part of it on. I was told there is a certain water pump that will bolt on and has the fan clutch seperate.
Here's my old setup.
Guess you don't want to see how it looks currently.rodmod720 wrote:i feel like crap after looking at that.i gotta take a rag to my engine bay
if that clutch fan does indeed unbolt from there then this will be a very easy mod.
yeah. it's a z22. i was hoping that it would at least be similar so he could use it thoughnis720 wrote:What motor is that? I see you have the aluminum valve cover and a manual fuel pump... is that a Z22 or LB motor? that might be the reason for your water pump being different.
they make t-stats to hook up to the fan that are fully adjustable. also the temp sensor for them is external radiator mount (well it pushes in between the cooling fins.)PEZi303 wrote:i'm planning on wiring mine to turn on by switch... don't know how complicated that will be
pics will be up tomorrow... ran out of daylight today2kredz3 wrote:mine is a 2.5 looking forward to the pics.
.mine are on the ignition switch. it's not hard at all. just tap into the fuse box and find a spot that is only on with the ignition.PEZi303 wrote:i'm planning on wiring mine to turn on by switch... don't know how complicated that will be
teaser pic of my z3PEZi303 wrote:pics will be up tomorrow... ran out of daylight today
very nice.PEZi303 wrote:i'm making a PEZi303's picture thread... it will be up shortly
hopefully all the green and silver will wear off in the near futurebreadbox wrote:looks good. I really like the green fan.
