Perrenial Badass »
https://forums.nicoclub.com/perrenial-badass-u98460.html
Thu Nov 06, 2008 3:32 am
Just buy a thermostat from Autozone or Advance. I personally bought one of the adjustible probe style ones. The electronic ones are more complex to wire up.
The simplest way to wire it up is to run a wire from the battery to the positive on the thermostat. Then run a negative out of the thermostat into the positive wire for the efan, then run a wire from the negative out of the fan to a ground. One of the bolts for the stock airbox is a good place to ground it. The kit comes with wire, but I'd suggest buying a pack or two of electrical connectors and some shrink wrap.
Once everything is wired up, unravel the probe, being careful to not pinch or bend the metal tube that leads to it. Attach the probe to the radiator as close to the fins as possible.
I'd suggest buying an inline fuse and wiring it in between the battery and the thermostat as well.
