Electric Fan
98TURBOKA
Car: HOME IMPROVMENTS-MOUNTAIN BIKING- EARNING MONEY-MOVIES
I was getting ready to replace my mecahnical fan with an electric fan setup. I think that I heard some place that the fans off of a maxima or and altima would work. Is that right? I want the best possable setup for the good of my motor, and I have a hook up that could get me setup with one from a salvage yard for next to nothing. But if would be better I would spend the money for an aftermarket setup. Also when wiring in the fan assy. I know that I can hook in to the a/c fan, but will that only work when the a/c is on? Do i have to hard wire it to a switch inside my car? Or can i hook it in some where that it would work like any other car- just start it up and drive? I do have a nsport turbo on my car so it does run a bit hotter, but I have the big azz skyline innercooler on it to help out.
daniel240
Car: cars/motocross
basically any kind of electric fan would work you just need to wire it up right. use the search button, theres tons of threads on electric fans.
trpower7
Word. Any fans will work that you can get secured flush with the radiator and wire up correctly.
