Electric Fan
DrewQ45
Car: 1990 Infiniti Q45
Q45denver wrote:
Yes, your lucky, but I've had four engines and several set of injectors in my 1990. Never had an alternator fail however. I think some of the new electirc fans are rated for 50,000 hours with nylon reinforced blades.
Replacing your thermostats at first sign of temp fluctuation will yield more longevity benefit than a fan swop...cheaper too. Your injector failure + my lack thereof may be location (gas) based. Can't say the same for the engine.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Q45denver wrote:Still not sure if the condensor fans run independent of the A/C being on.
It does once coolant temp gets above a certain temp (something like 200F its in your FSM).
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Thanks, Wes Is that true for the 1990 as well?
elwesso
2007 BMW M Coupe
Yeah, 90-93 Q actually had a seperate temp sensor for that whereas the 94 has a seperate control.
Q45tech
It all depends on which year Q [90-96] as to exactness however all generally engage the aux condenser fan when the radiator output temperature exceeds 194F this means a head coolant output of 200-210F.
The temperature drop across the radiator depends on rpm and ambient vs coolant vs ac heat gain from condenser?
Anyway it's bad foor the ecu to see 195-200F from coolant temp sensor as this begins the summer overheat ignition advance reduction!
Q45tech
Considering the amount of gas guzzler tax [$2100] that was added to each brand new Q's sale price don't you think that Nissan would have used electric fans if they could improve MPG even by 1 which would have saved $400 or 2 mpg which would have saved $800.
The 90-96 Q has a combined 18.7 mpg [used to calculate deficit below 22.5]
TBrack
Car: none
Q45tech wrote:Considering the amount of gas guzzler tax [$2100] that was added to each brand new Q's sale price don't you think that Nissan would have used electric fans if they could improve MPG even by 1 which would have saved $400 or 2 mpg which would have saved $800.
good point. it seems they don't care about it too much
Skibane
Car: 2000 Q45 AE 110K
Q45denver wrote:Increased reliablity of alternator and batttery offsets increased relaibility of engine, injectors, waterpump, hoses, etc?
Getting ANY extra engine/injector/waterpump/hose reliability by installing an electric fan is pure speculation - but the adverse effect it has on alternator and battery reliability is an indisputable fact. Hanging an extra 20-40 amp full-time load on your electrical system WILL shorten the alternator and battery life expectancies.
Quote »A mechanical fan with a clutch is more simple than an electric motor with a thermostat?[/quote]Yep.
A mechanical fan with a clutch is simpler than one or two electric fans, their assocated relay(s), thermostat, fuse/circuit breaker, wiring and connectors.
