breadbox wrote:Is your clutch fan not sufficient. On my truck with the stock shroud in pace it pulls alot of air. And figuring that the fan only actually does something at low speeds and idle, why switch to e-fans? they can be an expensive swap to get right. I.E. wiring with a stat so it turns on when it is supposed to. wiring it to run all the time isn't great and a toggle switched fan is a horrible idea, I like how clutch fans work.
Clutchless fans are rather noisy and are a constant drain of engine power. Heres what I did. Unfortunately its all custom so it was a little expensive - US650 - for it all.
Note the temp sensor on the top tank of the radiator.
When I get the truck back from the electrician I post the wiring done.
