240SicknessX wrote:i recently was driving around with a snapon scanner in my car and was watching the coolant temprature. Normal crusing around town was 176-178 degrees. Highway at 70 mph, 174-175 degrees for about 10 miles. Sitting still at idle 8-10mins the temps never went above 191. Snapon scanner with factory '96 coolant temprature sensor. Factory Radiator, factory mechacical fan w\ shroud inplace. 70% water\ 30% coolant. Out side temprature was around 82 degrees, with a 30x10x3 (core) spearco FMIC blocking direct airflow.
the A\C was off while i recorded the numbers and there really wasnt much change in tempratures, maybe +2 degrees around town.
I hate to bring this back from almost 3 yrs ago but i read what u wrote and i find it funny that my results are the EXACT opposite of urs....
I have the stock 98 ka radiator, stock thermostat, 50/50 pre-diluted antifreeze, dual 12' flex a lite fans and small fmi 24 x 6 x 3.5 Each fan is wired to its own fuse and relay with one adj therm set to kick on at 180F...
Sitting at idle for 10-15 min ( NO AC ) my water temps cycle between 165-183. Thats from the fans comming on at 180... then cooling down to 165 and shutting off. Cycling like this over and over... providing that i do NOT move....
Cruising at 40mph ( 10+ min NO AC ) my water temps reach ~190 and stay there as long as i am moving.... fans are on the entire time.
Cruising at 60 mph ( 10+ min NO AC ) on the hwy my water temps reach 200F and stay there solid the entire time.... and the fans are running the entire time.
Speeding at 80 mph, same results as above... 200F and holding there solid.
The ONLY time my hwy temps dropped below 190F was when the outside temps were 50F and below....
Obviously there is an air flow issue at hwy speeds for my setup, but urs is completly different......
