WDRacing wrote:Well you could hard wire it to a constant on or a toggle switch, but then you have to remember to turn it on. Or the car takes alot longer to heat up.
MaxType 240 wrote:I hope you didn't spend extra for the temp sensor box. I paid $210 from Summit w/ the box and that thing is a POS. It's bulky, requires a lot of wiring, it's failed twice on my buddy's SR. Use the wiring already existing in the car.
Have the 2nd fan kick on w/ A/C or when the coolant temp sensor hits 90C.
It's about time you got some decent cooling... Go w/ straight distilled water and Redline Water Wetter or Royal Purple's version.
Jesse
Jesse
What did you use to cut the fans? I have to do something very similar but I don't know what to use to cut themscotty-2-forty wrote:My choice ... recieved it today ... FLX-210B (twin 10" fans with adjustable thermostat and a/c control). I also bought a used FSR aluminum radiator, however for an SR20 setup. It came with a crossover tube since it was being used on a KA setup by the previous owner. I will not be using the new fan brackets and I will also have to cut the bottom of the fan casing for use with my radiator. But hey, I saved about 2-300 bucks over a new aluminum radiator ... even though I'm now on a tighter budget, I still believe in quality . Once it's installed, you'll never know the fan casing was modified. It'll be a few days before installing, but I'll post pics when it's done. Thanks for everyone's input.
