Want to make sure everything is working with my car correctly. One day I will replace radiator because whynot. Thermostat has been done. Also have replaced coolant with fresh coolant also replaced the other thermos (gauge/ecu senders)
My main point is my electric fan only kicks on when AC is on and it will stay on even after car is shut off...but only if I used AC on that drive.
I live in AZ yesterday was a cooler time for us of 107. I want to make sure it is functioning properly and if not which part needs to be replaced to tell the computer to kick on when it is too hot.
Hate asking this...
I know its a dumb question but I'm hoping some of you can chime in saying you had some problem or this is normal... it is usually a little above half per the temp gauge inside..
Thank you
